So I installed EFILIVE at my shop also to put it up on split screens and noticed that my laptop is a older version Efilive- when I modify the file at my office it wont open on my laptop- I wonder if this is why some cant read some of the files I upload
if I update will it mess all my files up on the laptop?
99 ECSB 1500 6.0 lq9/243 2wd 3.42 in the works.
Efans - CAI - Walbro 255lph - Eaton LSD
BTR STAGE 3 truck cam - 60lb Inj - MP122HH
FLT Level 5 - 3000 SC YANK
Pacesetter LT's - ORY
13.170 @ 103.33 Mph -
Updated efilive can read old tunes. Update the laptop and you'll be fine.
I have a feeling the reason I can't see your maps is cause of something I'm doing wrong.
Some things:
- in tunetool, go Edit->Properties and set VE units to g*K/kPa and fueling units to EQR, click Ok.
- in each of your maps, goto the Data tab, set Precision to 3 or 4.
Hint: SELBEN should be within the range 0.80 to 1.09... if it is outside that range, then something is going wrong.
Sanity check:
1. you are doing Calc.MAFT to correct the VE table (ignoring the MAF calculation portion for now)...?
2. you are getting a MAF DTC (which causes PCM to use only VE)...?
Just seems like the 10.xx number drop seems a little extreme. But I'm not a pro. The graph has many spikes which I know will need to get smoothed. . Plus when I tried it the truck for sure wouldn't idle
I'm on vacation I'll have to check all the settings when I get back.
Thanks for the help you two
