99 ECSB 1500 6.0 lq9/243 2wd 3.42 in the works.
Efans - CAI - Walbro 255lph - Eaton LSD
BTR STAGE 3 truck cam - 60lb Inj - MP122HH
FLT Level 5 - 3000 SC YANK
Pacesetter LT's - ORY
13.170 @ 103.33 Mph -
Wow, so a single beer and battlefield 4 and apparently I post like a tuning-tough guy lol. No I had 2 months of fuel pressure issues and issues from not initially having a clutch switch, and throttle cracker issues. So by the time I was doing my real runs I was confident I could take it up to high rpm.
You're a cool friend. Keep going and it will be a real solid driver.
Sent from my LG-LS980 using Tapatalk
lol
you add a little more to the high end of the VE to be safe (so that the tuning process brings it down to the correct level).
I was zoomed out a bit more, Look at 2740 to 2750,both nb02s go high(going high on nb02s doesn't give a lot of info), so look at the WB02 reading, if I remember it was an EQ of about 5 or so.
As for 5760,let me recheck the frame it happened during bedtime. But you should be able to find it, your just looking for the WB02 EQ channel to go above 1.7
frame 5760 -I was looking at log "Log_10 eway to shop 2 4_15_16". The pic below plots WBO2LAM from that file and shows lean (also the HO2S11 and HO2S21 both go lean. Are we looking at different logs?
My Cam is the TSP 228R ground on a 115LSA. I don't remember the specs, but the duration and lsa will give you overlap(and thusly how much effort it will take to tune).
When Joe was talking about fudging number from "4K to 6K rpm, and above 75kPa", that's what I was referring to about multiplying those areas by 1.10 (10% increase). That usually makes you run safely rich up high when you go zinging it up to the moon. Then CALC.MAFT will dial you back down to where you need to be.
Got a electronic fuel pressure gauge yesterday from a friend- will be giving updates soon on pressures
