Results 1 to 5 of 5
Thread: Stock 6.2 e92 tune
    Mar 2016
    Default Stock 6.2 e92 tune
    Hey guys I am needing to see if any of y'all have the stock e92 6.2 file. I was tuning a buddies truck and I am getting a checksum error. So I assume his ecm was tuned on before. Any help would be appreciated.
    Dec 2012
    I do. PM or post your email
    2005 Cummins - EFILive Conversion - S474 single - 1325hp on the spray.
    Quote Originally Posted by Bmccumpsey View Post
    If you are running current software you can fix that yourself without needing another tune. Yes it is usually caused by aftermarket programmers trying to disguise themselves.
    Search and see if you have this calibration:
    {B9999} Flash Checksum Fail Fix
    If you are getting a checksum error at the end of a reflash please check this value, if it is anything other than 65535 this may be the reason. Please change the value to 65535, resave the file and attempt the flash again.
    Lifetime Member Road's Avatar
    Feb 2015
    You didn't specify a year here is a 2014 hope it helps.
    Mar 2016
    Quote Originally Posted by Road View Post
    It was for a 2015 but I did end up figuring out the checksum error. If you search for CVN you can change the value like stated and that fixes the problem. Thank you both for your quick replies and help. In all of the googling I saw the error was common on previous versions but did not see what the exact fix was. Thanks again
    Bobby
  1. E92/T43 Tune help
    By kylelavergne in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: February 3rd, 2016, 04:39 PM
  2. E92 14/15 Silverado 6.2 stock tune?
    By VortechC5 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 2nd, 2015, 12:21 PM
  3. Cant open e92 2014 sierra tune file on v7
    By 400ss in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 10th, 2014, 11:51 AM
  4. stock E92 file ... ?!
    By Ls1_Rulz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 30th, 2013, 08:33 PM
  5. Any body have E92 stock file ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 16th, 2013, 10:31 AM
