Results 11 to 20 of 51
Thread: Unofficial E47 (LUZ) Full Tuning Support
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Figures. My Cruze gets rear ended and totaled then support comes out. lol. At least I have my mothers car to tune on. Looking forward to having support for these baby diesels.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Dec 2015
    Quote Originally Posted by dansdieselp View Post
    Rough. What did you replace it with if I may ask?
    For 'tuning' I'd say the cax has anything you would want. Certainly could be presented better, so I'm working on a bit of a face lift to make it easier to work with.
    The issue comes when you want to start tearing components out. Getting that to work is not easy. Mainly because these Bosch ECUs are masterful at making things look spaghetti.
    Apr 2009
    2016 Colorado 2.8L on order. Will be in early April.
    Quote Originally Posted by Snipesy View Post
    Agreed, I hate them.
    Dec 2015
    Maybe some of you may find these pictures interesting... Assuming my maths are correct.
    Dec 2014
    Snipesy, was waiting for this so long.
    Thank you for all you doing and sharing your tremendous hard work.
    Pure gold to me all you done and doing.
    Dec 2015
    Next update (code named Memorial )is bringing names to the DTC type table.
    Could be useful, changing the type will work a bit differently than changing the activation table to 32768 (32768 effectively signs the short int so it becomes 1000000000000000, a negative number). In reality I think it'll be more just a quick reference. Should also mention that in reality they would be a crap ton of "X | Not Reported" (or a null type would maybe be more accurate). But because the Bosch DTC tables have a crap ton, I filtered all of the unused/reserved spots. I think the tables have somwhere around 900 elements each.
    Also added some tables used for said DTCs, like desired boost upper/lower error everyone is familiar with. They look kind of funky... Hopefully the scaling is correct.
    Other stuff as well. I added the MAF Sensor curve... Had that for awhile, but I'm not really sure how that thing is scaled, so I just did a bunch of logging and approximated. Should be pretty close though. Additionally there is support for the older OS. Turns out they are almost exactly identical so I'm told.
    Fun stuff!
    Apr 2009
    Looks good man.
  9. #19
    You deserve a medal for understanding the abomination that is Bosch DTC tables.
  10. #20
    Dec 2015
    Good news making the tables is done and over with. I had a script match all the indexes together, and make a cax for me.
    Also look what I found. It's the tables that calculate the timing for the post injections. Interestingly mode 0 is pretty much just not used (it's blank).
    Useful? Not really. But the whole point of me figuring this out was so I could figure out the post injection quantity tables. Which are useful.
  1. E47 Cruze diesel dyno runs
    By cindy@efilive in forum E47 LUZ 2.0L (Family-B) Diesel
    Last Post: January 19th, 2014, 01:21 AM
  2. full BBL support for newer controllers?
    By Boost in forum Black Box Logging
    Last Post: May 27th, 2013, 10:30 PM
  3. E-ROD Tuning Support
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2011, 01:21 PM
  4. 4.2L I6 LL8 full OS support when??
    By ScarabEpic22 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2006, 12:30 PM
  5. Can you help implement 98 Tuning support?
    Last Post: February 22nd, 2005, 10:44 PM
