Results 1 to 10 of 11
Thread: 05 lly 30% over injectors
    Aug 2012
    Default 05 lly 30% over injectors
    Tune on these lly in stock injection more then the bigger injectors ones. I have a generic 100hp tune in it max 20* timing right around 2000uds I have a fuel knock which I kinda figured would... I can sit in there and tweak till I get it but the duration on 30% over v's stock how much should I cut back on that and mm3 where should start to cut on that?.?... thanks for any input as soon as these roads dry I'm going to do some more testing for sure
    Ethan
    Aug 2012
    Bump.... Anyone
    Apr 2014
    so u working with 30% injectors and any other mods on the truck. and what u use the truck to do.
    Aug 2012
    I did fass on it to keep up with supply it was the typical intake exhaust Egr delete and such.... I flashed a 100hp tune in it I could send you but the injector rattle was loud. I flashed in a dsp and went stock-extreme the extreme sounds the best the rest are noisy as in injector/fueling knock I've tried very little as time is precious around the shop here but runs great... Just like to get the noise down a little and the stock tune it likes to pop and crack at low rpm and white smoke like a rail pop issue haven't tried my revised tune yet for that but I have made one to try to get it to stop
    Apr 2014
    u can email me both files and stock file for the truck and see what is going on with it. pm me for my email buddy
    Apr 2014
    Aug 2012
    Pm sent!
    Apr 2014
    I sent u a email last night
    Aug 2012
    I didn't receive it or it has been deleted somehow..... please send another!! thank you
    Apr 2014
    resent buddy
  1. 2004.5 LLY can I use 2006 LLY tunes?
    By Badass_chris in forum Duramax LLY
    Last Post: October 22nd, 2012, 04:16 AM
  2. 05 LLY Help
    By jarasic in forum Diesel
    Last Post: August 9th, 2010, 09:17 AM
  3. LLY - Just do what I say!
    By GMPX in forum Duramax LLY
    Last Post: May 19th, 2009, 10:29 AM
  4. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
  5. Going from 28.8 injectors to SVO 30# injectors
    By 02 pewter Ls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2005, 01:47 AM
