Originally Posted by
Prormk163
I am currently trying to get my LC-1 to work with the scan tool to be able to log, however it will not display when I am monitoring real time data. Here is what I have set up
LC-1 :serial in is capped
serial out to rs232.
rs232 to null modem adapter
null modem adapter to usb (to V2)
I have read through the serial wide band tutorial, and have calibrated my lc-1. And the lc-1 instructable. My lc1 displays AFR on the digital display, and when i show WO2 display on the V2 it displays the correct AFR. My problem arises when I add my PIDS and monitor (in the scan tool), it shows AFR at ten, and EQ ratio at zero. I have made sure I have the sae_generic file which displays the correct code for values. I have spent about 8 hours reading the forums, trial and error, and I just cant figure it out. I hate wasting others time asking silly questions which seem juvenile to the level most are probably at, but I have spent an adequate amount of time and just cannot get it set up right. Any help would be appreciated. Also, my software and firmware are up to date.
-One other thing. When reading through the tutorial the V2 on the tutorial displays com-in and com-out both set to wide band, my flashscan only displays com, which i set to wide band.
Thanks for any help in advance!
