Results 1 to 4 of 4
Thread: PID for injector timing advance
    Jul 2012
    Default PID for injector timing advance
    Is there a PID to log injector advance? I'm trying to calculate SOI and EOI to compare against commanded camshaft advance angle and to monitor EOI vs spark advance difference while adjusting my spark advance.
    Thanks in advance
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Jul 2012
    I probably should have mentioned it's an e92 controller on a 2014 Sierra, 5.3L
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    I don't think so sorry, it is probably not something GM considered necessary for Diagnostics.
    Jul 2012
    Hmm.. That's annoying.
    Can you tell me if this will work like I expect it to?
    I figured out how to update the e92_links.ini file and changed all the links using E92_APCYLAIR_DMA to use CALC.CYLAIR, so I can at least see the runway highlighting in the tune file, which will get me close to the right cell when I highlight a section of the log file.
    Then I have a map where I am calculating CAdeg the injectors are open. I can at least get close that way. I know there are some adjustments the ecm makes to the actual SOI event from the MULT tables that I can see in the tune.
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
  1. High_Low Timing - Spark Advance (MAF).map
    By Tinbender59 in forum Tutorials
    Last Post: June 19th, 2015, 11:03 AM
  2. Base, Advance, Boost, IAT Timing
    By O1Z06 in forum Gen III V8 Specific
    Last Post: June 8th, 2011, 02:10 AM
  3. injector timing
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: January 18th, 2010, 12:17 AM
  4. PE Timing adder? Commanded advance differs from actual
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: March 28th, 2009, 04:31 AM
  5. Headers vs. timing advance
    Last Post: August 7th, 2006, 08:03 AM
