Results 1 to 8 of 8
Thread: OS: 12646249 LML file
    Dec 2015
    Default OS: 12646249 LML file
    Hi
    I have a file for a 2011 LML that i would like to use for this truck the problem is the speedometer segment dosent match with the VIN of the truck. Does anybody know if i do use this file what would happend or does someone have the exact file i am looking for?
    this is the file:
    Boot: 12646251
    OS: 12646250
    Main OS: 12646249
    Engine: 12655862
    Speedometer: 12646573
    System: 12655887
    Fuel: 12646325
    Engine Diag: 12655871
    Engine Operation: 12655865
    Lifetime Member IdahoRob's Avatar
    Apr 2006
    It'll run, but sometimes small things like the 4x4 light, etc can act up. You can try it and if there are issues then Tony @ Ridgerunner sells stock tunes.
    2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
    2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
    1965 El Camino, duramax 9.6 @ 149MPH
    All EFI tuned by Adrenaline Truck Performance
    Dec 2015
    Thanks for the info Rob I did try it truck runs great but the stabilitytrac light is on. Lost of communication error is the code. So I will have to find the right file.
    Lifetime Member Mitco39's Avatar
    Jan 2009
    Tony is man for stock files! Very quick at getting back to you.
    Mar 2009
    I probably have it, whats the VIN number? Your speedo segment doesn't match any of my files, so it may be an updated segment, and I may have a file with an older update to it. Need the VIN number to see the segment history to see.
    Dec 2015
    Finally got a file from tony. Great service from tony. Thanks for the help guys!
    Dec 2020
    Quote Originally Posted by David View Post
    Tony can you message me? I have a 2015 duramax lml that I bought out of state and I have some questions for making it smog legal in California
    Dec 2005
    Quote Originally Posted by Military_diesel View Post
    You can contact me, thanks
    www.mscservices.net
  1. Stock LML File Library?
    By Coletrain45 in forum Duramax 2011+ LML / LGH
    Last Post: August 28th, 2015, 05:14 AM
  2. LML File Library
    By Coletrain45 in forum Diesel
    Last Post: July 30th, 2015, 07:20 AM
  3. Lml bin file.
    By RADustin in forum Duramax 2011+ LML / LGH
    Last Post: June 1st, 2014, 11:23 AM
  4. Can't get LML file to to open 911 help!
    By 2012Dmax in forum Duramax 2011+ LML / LGH
    Last Post: May 30th, 2014, 03:41 AM
  5. LML .cax file
    By cokane1 in forum Duramax 2011+ LML / LGH
    Last Post: November 28th, 2013, 02:02 PM
