Results 1 to 9 of 9
Thread: looking for stock lb7 zf6 file
    Mar 2016
    Default looking for stock lb7 zf6 file
    I am in the process of making a truck work that the owner converted to a zf6 manual transmission. It is a 2003 lb7, 2500, crew, shortbox, 4wd, LT all options except sunroof. Can someone provide me with a stock file?
    Feb 2012
    Do you know what OS and segments you need?
    Mar 2016
    Id like to look at a complete file so I can compare to what we have and build a good driving cal for a manual transmission truck. The lb7 in question has mannerisms similar to my factory zf6 lly when it had factory tuning. No power under 1700 rpm and then a rapid, almost hard to control torque rise between 1700-1900 depending on conditions.
    Apr 2014
    I have a 2003 lb7 zf6 file. I did a dsp5 tunes on it a month or so ago
    Mar 2016
    Do you still have the stock unmodified file? Could you share it? Please.
    Feb 2012
    See attached, this is a 03 2500 crew cab, short bed, 4x4 manual engagement, zf6 truck.
    STOCK.ctz
    Mar 2016
    Why does the file show the transmission as automatic? Were trying to get the pcm not to search for a tcm.
    Apr 2014
    hey matzkediesel pm me I got a few files u can use
    Feb 2012
    It shows manual on my screen.
Name:	Screenshot manual.png
  1. LB7 Cab and Chassis Stock file
    By LBZoom in forum Duramax LB7
    Last Post: June 16th, 2015, 05:13 PM
  2. Looking for an LLY ZF6 stock OS
    By JustinD in forum Duramax LLY
    Last Post: August 18th, 2014, 11:14 AM
  3. LBZ ZF6 stock tune
    By koolky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 7th, 2013, 06:35 AM
  4. Wanted: Stock Vortec 8.1L / ZF6 manual trans file
    By Russell in forum Gen III V8 Specific
    Last Post: April 22nd, 2013, 04:49 PM
  5. Stock LB7 File?
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 06:50 AM
