Results 1 to 10 of 17
Thread: Why doesn't my 07 corvette ever hit 100% TPS at full throttle?
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Default Why doesn't my 07 corvette ever hit 100% TPS at full throttle?
    Doing some logging and tuning today on my 07 corvette and just noticed in the log that when wide open it never hits 100% throttle position. Is that how it is supposed to be? Here is my log. It shows it maxes out about 88%. Is this normal?
    Jul 2007
    After some searching it seems I may not have the correct throttle position PID selected. Anybody know what PID I need?
    ETCTP or similar I believe.
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Try GM.TPDES
    Jul 2007
    I just went out and selected all those type of pids and turned the ignition on and it still maxed at 88% when pushed to the floor. I thought possibly it was the aftermarket throttle controller so I unhooked it and put it back to original and still the same thing
    Lifetime Member Move'n Up's Avatar
    Oct 2015
    You may just have a bad TPS sensor or it may need to be calibrated if it's ever been replaced or removed for any reason.
    2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
    Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
    2017 Corvette 3LZ Z06 M7 with Z07 Package
    Jul 2007
    If it was bad wouldn't it throw a code?
    Jan 2006
    88% is WOT. Take your air intake off and with key on engine off have someone hold it to the floor, it show 88% and the TB will be all the way open.
    Aug 2010
    If you log TPS %, then you won't see a value over 88% (as it is calculated from the voltage).
    Log:
    GM.APP - for the position (%) of the APP (accelerator pedal)
    GM.ETCTP - for the position (%) of the throttle body
    Both of these PIDs range from 0% to 100%.
    Jul 2007
    I tried to log those you have listed but it didn't do anything. Kinda strange.
  1. Replies: 11
    Last Post: September 4th, 2013, 10:00 PM
  2. When throttle kickdown is not set at 100%
    By joecar in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 27th, 2012, 06:34 AM
  3. 50% APPS / 100% TPS w/ DBW. WTH. LOL. HELP!!!
    By wayneosan in forum Gen III V8 Specific
    Last Post: August 20th, 2011, 05:11 AM
  4. Pig rooting on 100% throttle.
    By Soopy in forum Gen IV V8 Specific
    Last Post: August 9th, 2011, 12:53 PM
  5. MAF'd Power Enrichment less than 100% TPS
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: March 19th, 2009, 07:00 PM
