Okay so I just tried again with some other pids selected. Perhaps I had the wrong ones? I happened to click on the "calculated" pids tab and say both rafig and rafin but these also stayed 0.00.
I didnt get much time as im in the middle of bbqing. I did only like a 2 minute COLD idle. Still have to crank it over like 4 times to start it cold. As soon as I got it close following the idle tips it created a hanging idle. So I set my IAC Airflows back to factory LS1. I want to say this has more to do with injector tuning. I recall my C5 vette when I ran 42lb injectors I had a hell of a time with start up.
IAC PARK AIRFLOW- Stayed pretty stead at 2.95lb/min (what exaxtly does this mean?)
Warmed up IAC P/N (same here?)
Warmed up IAC in gear (same here?)
I also logged my PCS it appears to be working but very very low amperages, meaning more pressure? Still need to further investigate this.
