Results 1 to 2 of 2
Thread: CM850 versus CM849
    Mar 2010
    Default CM850 versus CM849
    I have searched here and could not find a answer as well as searched on the internet... I am building a 4b cummins and I want it to be a CR engine. Since I work for a company that refurbs diesel generators I have access to a few CM850 cummins ecu. I read one post on here that a gentleman mentioned that he thought the cm849 was the same as the cm850 except the cm849 was for dodge only? Can anyone verify this? I also found where someone said that once a CM850 has a "industrial" "Offroad" program in it that it overwrites some part of the memory and cannot be flashed for a "ON Road" program. Can anyone verify this as well?
    That is correct, the CM849 was a Dodge specific ECM, the CM850 uses a totally different CAN protocol.
  1. Unable to Connect CM849
    By nm2769 in forum Diesel
    Last Post: February 1st, 2016, 01:54 PM
  2. Replies: 12
    Last Post: February 1st, 2012, 08:17 AM
  3. Gallons versus CI
    By Chevy366 in forum Lounge
    Last Post: August 23rd, 2010, 04:14 AM
  4. Car Start/Idle versus Logging
    By bobbycollier in forum General
    Last Post: January 17th, 2009, 02:21 PM
