I just kept trying without disconnecting from V8. It finally took. Had me worried for a little bit.
I had another episode of the checksum failure with a calibration flash on the same TCM A50. Everything matched before the flash attempt as well.
Ecm has flashed fine every time except one time. That has been since I updated to the pre-release. TCM has been the problem.
OK, just trying to determine if it is vehicle issue or specific to the TCM, sounds like it is specific to the TCM.
Tony ut did everything you asked if it? Shifted at desired rpms, speed and locked up just like you ask it to? Did you actually check to see if it did all if theses items? Thanks
Guys just something to be aware of. Your V2 must be plugged in to the USB port when V7.5 is first opened for these calibrations to become visible. That also means you must not have V8 running at the same time as it will not release the USB port to V7 on start up. Just something to observe when you first run V7, look for the LED's on the V2 to flash briefly as the software starts, this indicates V7 has negotiated with the V2 what level license the unit is (which is what determines if those cals show).
I had the BETA cals and tested on my 2012, tested a 2013 OS as well, I also sent a file to one of my dealers with a 2014, it followed my changes.
The A50 Beta forum was very quiet, I assume the other testers had similar results as I did, if they did not they would have brought it up in BETA that something was not working, it was like crickets in there, no complaints or issues.
Only one tester stated otherwise, and he had issue with only the Normal Maps, I had none when I cross tested the OS he uploaded.
Not sure what else I can add. Send me the file you have issue with, along with the changes you made and I will test it.
It may be the way you are setting up the changes
10-4.
