Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: March 2016: EFILive Pre-Release
  1. #21
    Lifetime Member wesam's Avatar
    May 2010
    I had a checksum error with E78 ECM yesterday i tried to full flash it but had the same problem
    I hope it will be fixed soon because i cant start my customer car
    Thanks in advance
    EFILive Tuner
  2. #22
    Quote Originally Posted by wesam View Post
    Thanks in advance
    Did you flash it using V8 pass-thru? If so can you locate the trace file and send it to me at paul@efilive.com. The trace files for V8 are located in \Documents\EFILive\V8\Trace
    If you didn't use V8 pass-thru, try using V8 pass-thru instead.
  3. #23
    May 2010
    Hi Paul i sent you an email yesterday could you check it please
    EFILive Tuner
  4. #24
    I didn't see it yesterday, went looking through my junk folder and found it. Looking into it now...
    The file had some residual Diablo data in it. I've removed the Diable data and sent you a corrected file.
  5. #25
    Lifetime Member Chavez91's Avatar
    Dec 2012
    Found something random. In the AL5 OS 15196784, in table {D5008} Part Throttle 5 -> 4 Shift Speeds, Pattern B reads the file from the wrong position. The 80 should be at 100 TPS% and there should be one more value that isn't shown in the 0 TPS% position (in my case its 71 KPH). I included a screen shot so you can see what I'm talking about. Not sure if other OS's are affected. I haven't checked as I don't have all the AL5 OS's but Ill see if I can check the ones I do have.
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
  6. #26
    Nov 2005
    Quote Originally Posted by S Phinney View Post
    Tony ut did everything you asked if it? Shifted at desired rpms, speed and locked up just like you ask it to? Did you actually check to see if it did all if theses items? Thanks
    We heard your A50 issues are now resolved via tuning changes, is that correct?
    Cheers
    Cindy
  7. #27
    Aug 2008
    Quote Originally Posted by cindy@efilive View Post
    Cheers
    Cindy
    Yes ,Cindy I can make changes now. The only suggestion and you may not be able to change this at all would be to see enough code so you could determine why or where the changes get sidetracked. For instance the speed changes do not occur at the set mph per throttle positions as previous tcm and software calibrations would allow. Your changes are dictated by Wot enable, wot up shifts, combination of apply and release in wot and part throttle. It is not something the layman tuner is going to jump into make a couple changes and get any results. I just had to approach it from a different perspective and with a little insight from Tony got it figured out. Thanks for checking with me on this. Tony, I appreciate the help.
    Shane
    Sent from my SM-G920V using Tapatalk
  8. #28
    Dec 2005
    No problem, was happy to help you get the changes to work more to your liking.
    Good Luck and stay in touch !!!
    www.mscservices.net
  9. #29
    Dec 2012
    Checked the other OS's I have. Seems to be just that particular 5 speed OS. But like I said I don't have them all.
    Sent from my Nexus 6 using Tapatalk
    Josh
    '04 GMC LLY
  10. #30
    Quote Originally Posted by Chavez91 View Post
    Thanks Josh, I have fixed it for the next update. Amazing to think it has been like that for many, many years (I would say since 2008) and only just got noticed and that is the popular OS too.
    The issue is probably only on that OS as all the table locations are entered by hand, it was just a typo on that line.
  1. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  2. March 2015, EFILive Release Candidate 1
    Last Post: March 20th, 2015, 07:04 PM
  3. EFILive Pre-Release 05
    Last Post: July 16th, 2013, 12:20 PM
  4. EFILive Pre-Release 06
    Last Post: March 29th, 2013, 04:15 PM
