Results 1 to 9 of 9
Thread: 2 bricked pcm's please help
    Mar 2008
    Default 2 bricked pcm's please help
    I made transmission setting changes to my tune and loaded it and it bricked the PCM. It ran all the way through and said flash completed successfully. When I hit OK my fuel pump went crazy and it wouldn't reconnect. I tried reflashing and full recovery and it just says PCM not detected. I pulled the PCM out of another vehicle and loaded the old calibration in it and everything was good. I then tried to load the calibration with the updated trans setting and it bricked that one too. I can't afford to buy new pcm's and licenses right now so I'm kind of screwed. What the hell is going on?
    What PCM/ECM and post the tune files please. Once we have that info I'd be happy to spot check the tune and then EFILive can take a look.
    Aug 2004
    My guess is you are messing with speedometer settings that are to wrong.
    Mar 2008
    Quote Originally Posted by wait4me View Post
    That is possible. I was changing to a 28" tire for the track so I was adjusting tire size and shift points. If that's the case, is it recoverable? I can post up the file later.
    What changes did you make...?
    Aug 2004
    send them to me and I can repair them. The chip needs pulled and redone
    Mar 2008
    How much to repair both pcm's? I tried to pm you and called.
    Aug 2004
    you called after the phones where turned off for the night probably. 7pm,
    Call during biz hours and I can help you out. Thanks
    Aug 2004
    Returned your call. Thanks
  1. Replies: 6
    Last Post: September 18th, 2014, 10:38 AM
  2. Bricked The V2??
    By RobsDmax in forum FlashScan V2
    Last Post: July 24th, 2013, 09:53 AM
  3. Bricked H3... almost
    By SwedeBurb in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 13th, 2012, 10:33 AM
  4. Bricked my PCM- What to do?
    By 67RsCamaroVette in forum Gen III V8 Specific
    Last Post: October 23rd, 2011, 08:02 PM
  5. PCM bricked while
    By Chuck L. in forum Gen III V8 Specific
    Last Post: June 29th, 2011, 08:46 AM
