Results 1 to 8 of 8
Thread: Modifying misfire detection tables ?
    Jun 2004
    Default Modifying misfire detection tables ?
    pretty much standard thing to do with a large cam is change the idle/low speed misfire detection to 32767 in all cells. been trying for a while to do that easily 9998 seems to be the biggest value you can put in in the 'adjust' box and hit #
    I would think the easy way would be to hit select all, put 32767 in the 'adjust' box and hit #, am I doing something wrong here?
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    Since mine only sets the code when I first crank it up, I changed the "Temp" parameters to -> 100*F and no more problems!
    Default Re: Modifying misfire detection tables ?
    Quote Originally Posted by kp
    Mmm, right you are, it has been added to the fixup list.
    Thanks,
    Jun 2004
    I really dont think there is another table that uses that big of value, my workaroound was just to type 100 in there and keep hitting % until all the cells were maxed out.
    The other option is to manually enter in the value of 32767 into a cell, then ctrl-c to copy the value, click on other individual cells and ctrl-v to paste that value.....might be a bit tedious, but you could populate a table in under a minute that way.
    Mar 2005
    Just want to confirm.. is this table C5622?
    Sep 2003
    If you select all the cells and change one and hit enter it will change all the selected cells
    Senior Member VortechC5's Avatar
    Jun 2003
    Mine does the same thing. Thanks for the tip. I just went in and changed the Min Temp, Startup Min Temp, and Startup Enable Temp to higher values.
    Quote Originally Posted by johnsZ06
    02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
    15 C7 Z5 1 Coupe - stock for now
    12 Avalanche - tune, Corsa Touring
  1. Misfire tables missing
    By 69camaro5speed in forum E37, E38 & E67 PFI ECM's
    Last Post: April 27th, 2010, 02:03 PM
  2. Replies: 11
    Last Post: April 25th, 2010, 04:47 PM
  3. Modifying TCC line pressure.
    By Joel_SS in forum Gen III V8 Specific
    Last Post: December 8th, 2006, 10:40 AM
  4. Question about Knock Detection
    By dc_justin in forum General
    Last Post: June 23rd, 2006, 02:30 AM
  5. Misfire detection table
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: January 20th, 2005, 10:16 AM
