Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: E92: VVE axis is MAP_BARO ratio...
  1. #11
    In the map that Ninety8C5 posted, click Show Units on each of Data, Row, Col tabs (just as a matter of procedure).
    Please edit CLC-00-401 to read this (the red part):
    *CLC-00-401
    factor 0.0 2.0 .4 "{SAE.MAP.kPa}/{SAE.BARO.kPa}"
    and then open the log file, make sure CALC.MAP_BARO is selected, and save the log file...
    and then post it here (or email it to me).
  2. #12
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    I made the change you suggested and will check the Units in the Map
    Thanks again for your help!
  3. #13
    Dec 2005
    You may have to create a calc pid for MAP/BARO ratio like Ninety8C5 did...
    Code:
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units             Low          High      Fmt  Expression
    *CLC-00-401
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code                      PRN  SLOT         Units            System           Description
    CALC.MAP_BARO              F401 CLC-00-401   factor           Tuning           "Calculated MAP-BAROMETER Ratio"
    Post your tune file here.
    I can copy and paste to a text but not sure how or where to put it (so it can show up on my e92 bbx) so i can install it ?
  4. #14
    Sep 2003
    It goes in: 'My Documents/EFILive/V7.5/User Configuration/calc_pids.txt' file.
  5. #15
    Quote Originally Posted by 69camaro5speed View Post
    For example, I added it to my calc_pids.txt as CLC-00-510, see attached...
    there are two parts to it, the CLC and the CALC.xxx that uses that CLC.
    ( you might also want CLC-00-100 from my file )
    For BBX, you can tell the BBL config to include V7 pid CALC.MAP_BARO... of course, you can't display any CALC pids on the V2 LCD while logging.
  6. #16
    Feb 2006
    Code:
    *CLC-00-401
    That is basically what i use for doing the e83 ecu also.
  7. #17
    Quote Originally Posted by Tre-Cool View Post
    Ok, E83 also, thanks, I annotated this in my calc_pids.txt file (attached).
    edit: updated attachment, again, once more; deleted attachment because it had other problem (mainly me trying to be clever ).
  8. #18
    Sorry, that calc_pids.txt had a few problems (not related to this topic)... here's the fixed up one.
  9. #19
    Dec 2005
    ok that works , now to figure out why in sd the throttle does not open all the way ETCPP1 99% TPS 58%
    I did not see any new codes hope to get back to this soon after doing 36 drag pack 2.9 whipple motors maybe my night job will have more time lol
    Thanks guys for the help looks like I was getting close this will sure make things faster
  10. #20
    Dec 2005
    pids are working great just need one to tell me why my throttle will not open lol. I have it up to 75%
    2015 gmc denali 427 cam 23x @.050 sd tune
    I have turned the tq response ,tq control,tq model in side out
    I have done stock up and down and side ways lol about 30 pulls in 4th gear
    any ideas
  1. E92 features
    By odd boy in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 6th, 2015, 11:51 AM
  2. E92 No data received,
    By 400ss in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 25th, 2015, 03:13 PM
  3. E92 GM computer
    By joelp in forum Petrol / Gas
    Last Post: November 15th, 2013, 09:25 AM
  4. E92 Not being supported yet?
    By 05gmcsierra in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 15th, 2013, 04:13 PM
