Results 1 to 2 of 2
Thread: advice on trans tunning for the allison trans stock and build trans.
    Apr 2014
    Default advice on trans tunning for the allison trans stock and build trans.
    I need advice on doing Allison trans tunning like how the title is. what tables to adjust and which ones to leave alone. I saw the calculator in the tcm
    Mar 2009
    The best advice I can give, leave it alone. Change shift points if you want, but I wouldn't touch a shift timing table, and do not even think of using the calcualtor unless you want to REALLY piss it off and send it into grade braking everytime you let off the throttle, or disable it all together. I really wished they would take that calculator out as I have seen guys DESTROY hard parts from using it and throwing everything off. Those few tables change SO MANY tables you can't see, it's ridiculous. We see less than 1% of what is in the trans tune with EFILIVE, so I suggest play it safe, keep your changes small, and only mess with shift points. I've got a TOASTED C2 stack because I changed a TAP base table to get my 3-4 shift to adapt quicker, little did I know that supposed base table wasn't just for the base set TAP, but affected ALL of it.
  1. 2003 c6500 3126cat allison trans swap?
    By TurboDave in forum Diesel
    Last Post: February 28th, 2013, 10:42 AM
  2. LS7 (441 CID) with Light Boost in 1998 Trans Am (Need MAF advice)
    By Black LS1 T/A in forum Gen IV V8 Specific
    Last Post: July 31st, 2012, 03:38 AM
  3. Replies: 0
    Last Post: January 4th, 2012, 04:42 PM
  4. trans tuning for the allison
    By Dmaxvaz in forum Diesel
    Last Post: February 16th, 2011, 06:57 AM
  5. First EFI build-L92/VVT/E38 with Tremec tko trans swap
    By kball in forum E37, E38 & E67 PFI ECM's
    Last Post: February 23rd, 2010, 08:45 AM
