Results 1 to 3 of 3
Thread: LB7 Speed Limiter/ High speed defuel???
    Jul 2013
    Default LB7 Speed Limiter/ High speed defuel???
    Been working on my first LB7 tune for a buddy, got a pretty good DSP4 made for his big power tune. Been chasing a weird de-fuel problem.
    Its not consistent, but usually around 90MPH, the pulse width will drop like a rock for no apparent reason. But the thing will continue to speed up, and eventually after some time or some throttle fiddling it will take back off clear to 120MPH with full PW.
    Other times its wont de-fuel at all.
    I have been through all the limiting tables I can think of, speed, trq.... ect.
    Nothing in the DTC looks like it would be messing with the engine.
    Anybody had this issue and know what the culprit was?
    I have the tune and data log.
    Frame ~1231 is a good example of the PW falling off.
    04 LLY Crew cab
    Complete LBZ intake
    EGR is gone
    PCV delete
    resonator delete
    EFI Live DSP5
    Jul 2013
    Quote Originally Posted by larski156 View Post
    bump
    04 LLY Crew cab
    Complete LBZ intake
    EGR is gone
    PCV delete
    resonator delete
    EFI Live DSP5
    Sep 2006
    I would take a look at B0732-B0736
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
  1. speed limiter
    By THEFERMANATOR in forum Duramax LLY
    Last Post: August 31st, 2014, 03:37 PM
  2. 04 LB7 Speed Limiter
    By Jonsey181 in forum Diesel
    Last Post: November 6th, 2011, 09:47 PM
  3. Speed limiter
    By RichardWebman in forum E37, E38 & E67 PFI ECM's
    Last Post: August 7th, 2009, 04:41 PM
  4. Speed Limiter
    By devil in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2006, 08:00 PM
Tags for this Thread
