Results 1 to 4 of 4
Thread: B0101 VE table display units
    May 2015
    Default B0101 VE table display units
    I need to set the B0101 table display units from kPa to % and can't seem to find the setting. My log is displayed in g*K/kPa and my B0101 table is displayed in kPa, can anyone point me to the setting for this?
    Nov 2013
    Edit. Properties.
    However, the top row in b0101 will say kpa, but the units of the data inside the map are displayed right above the description, to the left of minimum and maximum. There is no setting to display b0101 units in kpa. Just sayin. 😀
    Use g*K/kPa everywhere.
    in tunetool: Edit->Properties->VE Units: set this to g*K/kPa (same as your log).
    Post screenshots (shift-prtscr) of what you see.
    edit: JetMech is correct, VE does not have units kPa... those are the units of the horizontal axis (the MAP axis).
    May 2015
    Here's a screencap after changing the units, thanks for that I couldn't go on without it.
  1. Setting efi live to display AFR units?
    By SharpA in forum E37, E38 & E67 PFI ECM's
    Last Post: October 14th, 2013, 09:15 AM
  2. Black Box display units
    By LBZoom in forum General (Diesel)
    Last Post: October 1st, 2010, 05:18 AM
  3. B0101 - Same whether using MAF or SD?
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: May 27th, 2008, 02:01 PM
  4. Configuring the calibration display units
    By Blacky in forum Tutorials
    Last Post: June 10th, 2007, 08:06 AM
