Results 21 to 30 of 40
Thread: Known issues with the April 2016 Beta Test Release
  1. #21
    Is there maybe a registry entry/value we can edit to disable it? I started looking through the EFILive reg settings but got distracted.
    No.
    The intent was to ensure that message was obvious and unmistakable to anyone running the software. It is possible (even probable) that at least one or two customers will install the beta software, use it for a day or two then not use it for months. Then come back to their laptop to use EFILive again, start up the beta software and forget or not realize they are still using a beta version.
    But a registry setting would be reasonable for those customers that use EFILive on a daily basis and know/remember what version they are running. So the next update should have some way to disable it - but it won't be trivial to disable it - you're going to have to really want to disable it
  2. #22
    Dec 2012
    Trying to Full flash a T87. And I keep getting this ERROR....... Can you not change Operating Systems?
    Josh
    '04 GMC LLY
  3. #23
    Use TIS on a new TCM (I know 24274017 is the blank OS they are shipped with).
    V8 will also not allow Allison OS's to be flashed over 8Lxxx OS's.
  4. #24
    Dec 2012
    That was my next thought. Lol! Any specific reason we can't just full flash it to achieve the same result as using TIS?
    Sent from my Nexus 6 using Tapatalk
    Josh
    '04 GMC LLY
  5. #25
    On a TCM probably not (we are maybe just being a little cautious), different story on a late model ECM though.
  6. #26
    Dec 2012
    Thankyou, sir!
    Josh
    '04 GMC LLY
  7. #27
    May 2010
    Is there any option in Beta that will mark the beta added tables to any Cal file with different color ?
    EFILive Tuner
  8. #28
    Aug 2004
    Another thing noticed Paul.
    When doing a compare of 2 files, and some values are normally hidden/ RED that only show up when a cable is plugged in. If you don't have a cable plugged in and do a compare, and the restricted tables have been changed, It shows up the table name on the compare list, but when you click it, it says name not found. It should just not show up in the list.
  9. #29
    No there isn't sorry.
  10. #30
    Dec 2012
    If you have V8 Scan And Tune open and then Double Click the Desktop Icon again (sometimes i have it minimized and dont realize its already open) you get a dialog box that says
    "cannot open Only *.ctz, *.ctd, *.tun, *.bin, *.pld, *.efi and *.dsh file types are supported."
    I think it used to just bring the V8 Scan and tune to the front without the error.
    Josh
    '04 GMC LLY
  1. March 2016: EFILive Pre-Release
    Last Post: April 7th, 2016, 07:32 PM
  2. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  3. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
