Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Known issues with the April 2016 Beta Test Release
    Default Known issues with the April 2016 Beta Test Release
    Currently known issues and possible workarounds for the March 2016 Beta Test Release of the EFILive Software and Firmware
    Download the April 2016 beta test release here: https://forum.efilive.com/showthread...a-Test-Release
    Download the public stable-release here: http://www.efilive.com/latest/cat/download-efilive
    Beta test release software versions:
    • Software: V7.5.7.304
    • Software: V8.2.2.295
    • FlashScan/AutoCal firmware: V2.07.98
    Issue 1:
    Workaround:
    None.
    It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Issue 2:
    When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
    Workaround:
    EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
    Aug 2004
    Issue 1.
    When opening a file to compare. If it is a Custom os file, and the other file is not a custom os, it will give you a floating point error and then when you do the compare f12, it shows every table is different. When you look at the actual difference, it is showing the values of 0 because the file isn't really open to compare. If you just hit update it corrupts the file.
    Putting 0s in every table.
    Quote Originally Posted by wait4me View Post
    Issue 1.
    Can you please send me the two files that you are comparing?
    Dec 2013
    I've sent a log and my tune file to support@efilive.com something is looking very weird about line pressure actual PID.
    It has functioned fine in the past when I view with auto enginuity. Will try AE again tomorrow to confirm.
    Quote Originally Posted by SASDakota View Post
    What controller?
    Dec 2013
    What controller?
    2010 CMD with CSP5 OS
    Ok thanks, because none of the logging was tested by anyone on a real truck prior to this being released.
    I haven't looked at your logs but if possible can you please log just the PID group with the Pressure PID's and nothing more to see if there is any difference. Thanks.
    Dec 2013
    Ross I logged line pressure actual (group7) this morning by itself in passthrough V8 and got the same result. Would you like the log emailed in?
    I got the log thanks and yes something is very wrong there. Would love to hear if anyone else has tried logging trans data on the 2010-2012 PCM.
    Dec 2013
    Ross I sent a whole new log in to support with some thoughts. Hopefully it is helpful.
  1. March 2016: EFILive Pre-Release
    Last Post: April 7th, 2016, 07:32 PM
  2. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  3. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
