Results 1 to 6 of 6
Thread: Lb7 help e54
    Apr 2016
    Default Lb7 help e54
    You guys are going to hate me with this one. Haha. I have an 03 lb7. This truck was all stock. I did dsp5 with tunes and position 5 as a lope just to mess around. I don't really like lope tunes but figured hey what the heck. Anyhow. I've done lope tunes before just not on my truck. When I go to position 5 the rpm just goes up maybe 25rpm or so. It just stays there. No lope. I tried anywhere from 10-60%. Still nothing. Just roughly 50rpm increase that holds steady. I even tried changing the lope to dsp 1,2,3. Still nothing. I even tried the 400 and 800 cells. Nothing. Now I don't really care about the lope tune just curious why it won't work on this truck. I'm even wondering if the full flash I did when I converted to dsp5 didn't fully take. Everything works well and all my positions work. I used late lb7 script. Just for the heck of it I loaded my complete file in my other truck. Still no lope in that truck either. It's odd. What am I missing. A torque table limiting it??? Idle parameters???? I can't figure it out. More curious than anything.
    Mar 2009
    For a lope on an LB7, all you have to do is put 50 into the 0.0% TPS table of A4102 at 600 RPM's.
    Apr 2016
    That is what I have. It won't work on this truck. I have done lots of lope tunes before. I usually put 21 in the 600 table at 0. I know how it works but on this one it won't. I don't need a lope tune. Just want to know why it doesn't work. My 1st post explains everything I have tried after it didn't work. Any suggestions
    Apr 2016
    Apr 2016
    With engine running how can I log/view cells that are being triggered at that moment.
    Apr 2016
    Lope works on stock thru DSP2 Does not work on DSP3 and DSP4. But my tunes do work on DSP3 and 4
  1. Replies: 2
    Last Post: April 28th, 2015, 01:25 AM
  2. LB7 help please
    By RUTAN TA in forum General (Diesel)
    Last Post: March 2nd, 2014, 12:29 AM
  3. 01 LB7 PCM in 04 LB7 truck?
    By KLUG'S SS in forum Duramax LB7
    Last Post: December 26th, 2013, 01:25 AM
  4. RR for LB7
    By GL4787 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 8th, 2009, 01:12 PM
  5. 03 LB7 pcm into 01 LB7
    By red12secz28 in forum Duramax LB7
    Last Post: November 19th, 2007, 09:40 AM
