Results 1 to 5 of 5
Thread: LB7 Duramax ECM
    Nov 2014
    Default LB7 Duramax ECM
    The LB7 ECM is compatible with the RoadRunner, correct?
    Dec 2005
    Yes, I have two.
    MOATES only offers a kit and it requires a separate EFI-Live RR License
    www.mscservices.net
    Nov 2014
    Yes, I have two.
    Can most parameters be adjusted with this?
    Dec 2005
    Anything you want in real time in the V7.5 editor.
    If its on the screen in your view and you are in the mode for real time tuning its going to alter the table in real time.
    IIRC its 12 seconds for a Full Flash DSP5 thru the USB.
    I used the two I have and it made tuning so much quicker when tuning live than re flashing every time.
    Well worth the $$$$ if you are serious about tuning LB7's.
    I do not use them much anymore, I have all of my base files and custom files and unless its a crazy build I just don't use them much anymore, I just had MOATES solder in new batteries and give them both a check-up last year.
    Its an awesome tool
    www.mscservices.net
    Apr 2016
    Where can I get one. Looks like on the site the parts aren't available anymore to make one. Anybody want to sell
  1. #0533 LB7 duramax
    By Keiko in forum AutoCal
    Last Post: June 10th, 2015, 08:18 AM
  2. Truck won't start duramax LB7
    By Keiko in forum Diesel
    Last Post: April 19th, 2015, 04:24 AM
  3. LB7/LLY Duramax crankshaft pattern
    Last Post: May 27th, 2009, 12:46 PM
  4. 03 lb7 duramax
    By mike37davis in forum Duramax LB7
    Last Post: January 9th, 2009, 02:16 PM
  5. 03 lb7 duramax
    Last Post: January 8th, 2009, 05:39 PM
