Results 1 to 10 of 14
Thread: Table for Alternator Control
    Jan 2006
    Default Table for Alternator Control
    In several LS3 engine swaps I have had to use a license in HPT just to turn on the alternator. How hard is it for EFI Live to add that to E38's?
Name:	Screen Shot 2016-04-14 at 5.24.25 PM.png
    Not so much hard, it is the time to do it that is always the issue for us. Between the E38 and E67 we support over 100 OS's so rolling it out over all of them isn't a small task. And I can guarantee if we only did it for a handful the next day there would be a request for them to be added in to an OS we didn't do.
    Dec 2005
    Alternator control no BCM I to need this control
    Aug 2012
    Can someone explain what the BCM is doing that the ECM is not? Ls1b controls it right. Why is it different? I see both alt wires going into the ECM just like the ls1b... sorry, it's confusing to me I'd like to learn more since I am currently doing LS3 swap.
    Jan 2006
    Quote Originally Posted by dgdyno View Post
    You will need to use another software in order to adjust it, efi doesnt have the table.
    Aug 2012
    I have TC and it gives me these options. Do I simply want to disable them?
    (Well the pic was right side up on my device...sorry)
    Jan 2006
    I use hpt for it and adjust the table in the pic in my first post.
    BTW: you can do SHFT-PRTSCR to get a screenshot.
    Aug 2012
    Looking at a stock vette LS3 tune in hpt shows alt remote/override settings disabled and not fitted. LS3 Camaro has them both active.
    Did the vette not have BCM charging control with current sensor on the negative cable?
    Try disabling some of those...
    but you would have to provide battery voltage to the alternator F or L input (via a relay activated by key-on... and a fuse ahead of tne relay), I don't remember which input, look at a wiring diagram for reference.
  1. Alternator control no BCM
    By l92Firebird in forum E37, E38 & E67 PFI ECM's
    Last Post: September 13th, 2023, 04:42 AM
  2. Cruise Control table(s)
    By greasess in forum Petrol / Gas
    Last Post: July 3rd, 2015, 11:48 AM
  3. AFR control by MAF and VE table combined?
    By 67SS509 in forum Gen III V8 Specific
    Last Post: January 4th, 2013, 08:29 AM
  4. Is a turbo control table a possibility?
    By Idaho CTD in forum Cummins 5.9L
    Last Post: March 12th, 2012, 10:42 AM
  5. Alternator Monitoring
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: June 8th, 2005, 02:21 PM
