Results 1 to 5 of 5
Thread: Converting a HPT File to EFI Live
    Default Converting a HPT File to EFI Live
    Hello,
    I recently got a basket case GTO in, that has an HPT COS loaded into it or whatever they call it. Wondering if anyone has the capabilities to convert it to an EFI Live Tune file?
    I tried to upload the file and it didn't work. so if this is something you can do PM me and Ill just email it to you directly. Thanks in advance.
    Jan 2006
    I can but its not always a 100% conversion, depends on what custom OS they used. Its also not cheap because I usually have to use 2 HPT license to do it. I can get LS1 pcms cheaper than that so I usually just get another pcm since its the cheaper route.
    I have a PCM, but want the calibration for a baseline. What would it cost roughly?
    Aug 2006
    Couldn't you go to the HPT website and download their software, then pay a local shop/person to read it out for you? Then put that cal on your laptop and check it out.
    Jeff
    Jan 2006
    Quote Originally Posted by Schwanke Engines View Post
    $200-$300 depending on year and PCM it is.
  1. Converting Ford style injector data to data useful to EFI Live.
    By JOHNBOY in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2012, 06:19 AM
  2. Converting a HPT to an EFI Live file?
    By Phantom Z in forum Lounge
    Last Post: April 7th, 2011, 08:27 AM
  3. HELP!!! Converting Efi Live to HPTuners file!
    By 06x6spdGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2010, 12:46 AM
  4. can anyone convert ant hpt file into efi?help,help
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: December 19th, 2009, 09:10 AM
  5. main differences from hpt to efi live
    By boostedyards86 in forum Gen IV V8 Specific
    Last Post: September 11th, 2009, 09:42 AM
