Page 10 of 10 FirstFirst ... 8910
Results 91 to 95 of 95
Thread: lq4 Tune help
  1. #91
    MAF DTC: good.
    ( without a MAF DTC the PCM still uses the MAF, and if the MAF is physically absent the PCM tries to calculate what the MAF would have read (which would usually be wrong) )
  2. #92
    Sep 2013
    Default Finally got parts.
    Alrighty well I finally got my Torque converter and new chain. I replaced them and its like a whole new animal, however after starting it up I now get codes po103 and po200. So I have to check my injectors and harness for something that may have came unclipped. And then Hopefully redo calc.ve.Log_0006.efi Here is the log with DTC's.
  3. #93
    P0103: If you're not running SD, check MAF and its wiring. If you're running SD then the DTC is required.
  4. #94
    Sep 2013
    Had a wire pull off injector 5, working on the maf issue. Seems like it's fine while logging, and my iat seems right (5 wire maf)
  5. #95
    P0103 is spefically MAF related, IAT has its own DTC's.
    To help troubleshoot it goto www.gearchatter.com and look at say 2000 Camaro DTC P0103, it will show you the factory diagnostic chart/procedure.
  1. NEED HELP LQ4 tune
    By zayne0 in forum Gen III V8 Specific
    Last Post: March 10th, 2016, 02:01 AM
  2. looking for a lq4 tune os 12597120
    By Lsjuan in forum Gen III V8 Specific
    Last Post: July 4th, 2015, 02:18 PM
  3. Newbie Question: LQ4 Silverado Tune from AT --> MT <?>
    By redXman in forum Gen III V8 Specific
    Last Post: October 24th, 2014, 01:57 AM
  4. LQ4 cable throttle with manual trans - need tune
    By Alaskanjeremiah in forum Conversions / Aftermarket Parts
    Last Post: July 16th, 2012, 10:21 AM
  5. Need base tune for LQ4 with MP112
    By bai78 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 27th, 2011, 12:12 PM
