Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 95
Thread: lq4 Tune help
  1. #21
    Quote Originally Posted by Prormk163 View Post
    Sounds good! I probably won't get a log in until Thursday, it's supposed to be cool here in northern Mn again and rain.
    Should I have done calc.Vet prior to AutoVe? If so I have not done so.
    If you're street tuning, do Calc.VET, and check your results.
    ( the names of the methods have been chosen to confuse the heck out of every one )
    Be sure to read post #29 here: Summary-Notes
    Calc.MAFT:
    - same as AutoVE (corrects VE) but also simultaneously calculates MAF (from corrected VE),
    - can be done with or without CL/LTFT (edit calc_pids.txt to use the appropriate BEN pid),
    - create a map for CALC.MAFT and directly paste this into B5001.
    Calc.VET:
    - same as AutoMAF (corrects MAF) but also simultaneously calculates VE (from corrected MAF),
    - create a map for CALC.VET and directly paste this into B0101.
  2. #22
    Sep 2013
    I am street tuning, and was planning on running a maf as the temps here vary so much. I've read pros and cons to both, if I plan to run a maf should I still do calc.vet? Or should I do calc.maf?
  3. #23
    The simplest is to do Calc.VET... see how this goes...
    it will go good if injector data is good, and if MAF/filter combination like each other (no plumbing bends immediately before/after MAF (MAF screen helps), filter baffled from engine heat and fan draft)...
    post picture of your engine bay.
  4. #24
    Sep 2013
    Alrighty I will do that! Did I harm anything by doing Auto.Ve first? I wouldn't imagine so since I enriched the table prior to starting the process.
  5. #25
    Nov 2013
    No harm in doing either. I just prefer calcvet or calcmaft because it fixes everything in one go.
    Sent from my LG-LS980 using Tapatalk
  6. #26
    Should be ok.
  7. #27
    Sep 2013
ID:	19546Click image for larger version.
  8. #28
    MAF may be too close to filter.
    Filter is not shielded from air movement from fan(s).
  9. #29
    Sep 2013
    I do have a shield for it. As far as the maf location, how far should it be from the filter? It must get inaccurate readings because it can't average properly due to turbulence and currents?
  10. #30
    Nov 2013
    At least 6"from filters or bends. In your case, right in the middle of that inlet pipe.
    6"gets you near - uniform flow. Turbulent flows are , as you know, random and will remove temperature from the mafs hot wire also randomly-leading to a fluctuating g/s reading in steady state operation.
    Calcvet will still work for the ve table part , but the maf part will be goofy til you fix it.
  1. NEED HELP LQ4 tune
    By zayne0 in forum Gen III V8 Specific
    Last Post: March 10th, 2016, 02:01 AM
  2. looking for a lq4 tune os 12597120
    By Lsjuan in forum Gen III V8 Specific
    Last Post: July 4th, 2015, 02:18 PM
  3. Newbie Question: LQ4 Silverado Tune from AT --> MT <?>
    By redXman in forum Gen III V8 Specific
    Last Post: October 24th, 2014, 01:57 AM
  4. LQ4 cable throttle with manual trans - need tune
    By Alaskanjeremiah in forum Conversions / Aftermarket Parts
    Last Post: July 16th, 2012, 10:21 AM
  5. Need base tune for LQ4 with MP112
    By bai78 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 27th, 2011, 12:12 PM
