Results 1 to 5 of 5
Thread: New Dodge owner
    Jan 2012
    Default New Dodge owner
    Hello all. Just picked up a 2011 Dodge Ram 2500 HD. Already has a full turbo back 5" exhaust with dpf and cat delete. Since there's no cel in I can see where a tuner was installed I'm assuming there is some sort of tuner already done loaded onto the truck. Would I be able to override the current tune? I know it's hard to answer since I'm not sure what tuner was used before. Thanks for any help
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    Member mpdtune's Avatar
    Jul 2013
    Yes you can. Any of the companies doing 4th gen tuning can take care of you.
    Jan 2012
    So all I'll need is to upgrade to the v2? All I see is the V2 upgrade with a GM licence. I guess I'll have to get the dodge licence separately and see where the trucks at.
    Yep, upgrade to the Cummins tuning option then you'll be able to flash any Cummins controller. VIN licenses are VIN licenses, they can be used on any controller type as long as you have the appropriate tuning license activated on your V2 (i.e. not GM or Dodge specific).
    Jan 2012
    Okay. The site had me confused. Thanks.
  1. 05 Dodge Ram
    By Zero1338 in forum Do you want to be a Beta Tester?
    Last Post: August 14th, 2012, 01:22 PM
  2. Dodge Tuning?
    By johnasara in forum Lounge
    Last Post: November 7th, 2011, 10:19 PM
  3. Where does a new EFI owner start?
    By Dream2000 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 8th, 2010, 02:11 PM
  4. Introduction: New LS3 and EFILive owner
    By 9secz in forum Gen IV V8 Specific
    Last Post: April 24th, 2008, 04:54 PM
  5. New V2 owner aka slowec
    By Slowrc in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 19th, 2007, 10:52 AM
