If one was to try and data log the pids to replicate this table what pid/s would it need to create " data: Xxx milligrams " value
One would be - GM.main1q_dma
The other - Sae.rpm
Data value - ?????????
The other - Sae.rpm
Is anyone able to figure out a pid to monitor the milligrams of airflow for this table ?
Going to be a tough one, doubt it would be easy or very accurate but you may be able to make a calculated pid based off of airflow with the actual engine volume and map minus the expected flow through the maf for given cid and map pressures, i'm math stupid so I would not be able to offer much help with the pid. What are you trying to do anyways I only know a few settings for that table and it's either "0" or "maxed" pending the type of ecm?
04 LB7
2010 LMM
2015 LML
Just trying to make the computer pass tests while having it blocked off.
