Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: 2012 Ram ECU BIN file
  1. #21
    Quote Originally Posted by MobileProg View Post
    All this is fantasy land theory BS anyhow. EFI crew has to play ball with the EPA to put bread on their table and not get the wrong people mad. You cant fault them for that.
    Thank you for this comment, I'm glad some people see how the real world works in 2016.
    The CM2350 would be a great hardware platform to use but I wonder how deep the copyright problem would go with reusing portions of Cummins own code, as in the boot code and I/O code that sets up the actual hardware itself.
  2. #22
    Apr 2015
    Not sure. I know a guy personally that has his own flash kernel for MPC5xxx devices. I think if you got Wind River Diab and VXworks you could go to town. MPC code plays nice in IDA between learning how it works and writing your own code it could be done.
  3. #23
    Then if you could do that you'd end up as senior programmer at Cummins without all the headaches
  4. #24
    Mar 2016
    Default cm2250 conenction example
    cm2200 is very similar, pay attention to oscillator your shorting, so far im reading it to back up the ecu just in case of failure, I use witech wit minivci pod2 to update ecu first just in case it was edited before by other tuners, (happened to me before and bricked up ecu) rest id done with efilive, some people r using cummins calterm to edit calibration settings and upload them back to ecu using engine bay diagnostic port, but theres same problem it cannot be read only programmed,
    btw I am very happy user of efilive, it deos everyth I want, I just wish for epa b gone spray
  5. #25
    Apr 2015
    Quote Originally Posted by piciu82 View Post
    Wonder if those points can be traced back to bootcfg0/1 ?
    Several oscillators. Without knowing the purpose its hard to know why they are jumping that.
    Did find bootcfg0/1. Thinking if one can tell CPU to boot from other location than normal you can then load custom code into that location and make it do your bidding.
    CM2200 Jtag
Name:	JtagProper - Copy.jpg
  6. #26
    Aug 2018
    Hi guys, thats a ecu read of 2012 dodge ram with cm2200 ECU
    p/n 5268444
    s/n 22486
    d/c 12/20/2011
    ESN 58098438
    E/C CM90017.03
    now what I can use to edit it, calterm ??
    ECu got a Motorola MPC5556 MPU
    I read it using alientech KTAG
    Hey there! Can you post the connections to do it please? Right now I have 2 of this ECMs, and mostl likely one of them is NEW. The other one is a job but need to read it and I cant
  1. 2012 Ram stock tune
    By turk88 in forum Cummins 6.7L
    Last Post: April 16th, 2015, 04:03 PM
  2. 2012 Ram 3500 Stock tune 12351331AN Please?
    By crdth in forum Cummins 6.7L
    Last Post: April 15th, 2015, 02:57 PM
  3. Lml bin file.
    By RADustin in forum Duramax 2011+ LML / LGH
    Last Post: June 1st, 2014, 12:23 PM
  4. Original Bin File
    By markemac in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2008, 12:57 PM
  5. HPTuners bin file
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2005, 12:30 PM
