Also, make sure you are using "Asynchronous 10fps" scan mode. You can selec the Scan mode to use in Properties window (Ctrl+Enter), on the [Logging] tab page in the "Scan mode:" section.
However, if you select more than 24 channels, EFILive will automatically drop down to Dynamic scan mode (usually about 6-9 frames per second).
If you sleect more than 36 channels then EFILive will drop down to General scan mode, usually about 1-5 frames per second.
Is the "Asynchronous 10fps" scan mode faster and more accurate than the "Dynamic" mode with 24 channels? I always used dynamic mode in V6 and never experimented with anything else. I might want to change my selection with V7 since I keep my channels to 24 or less.
