Results 1 to 10 of 20
Thread: Calc.MAFT and odd results
    Feb 2016
    Default Calc.MAFT and odd results
    I went through the Calc.MAFT setup and have been using it to tune for my cam. Overall it's worked fairly well to get a general tune, but it seems like my commanded AFR is either off, or EFILive thinks that the actual AFR that my wideband is off (though the handheld is showing the proper value). Essentially, I will have areas, say low speed cruising, where the AFR is 13.5-14.0, and one spot right at 2000 RPMS where it goes super lean, 16.5-16.9. I will let Calc.MAFT do the logging and all, and the end result is 1.0, basically it thinks that the AFR reading is spot on.
    I can fine tune it, but trying to do this on a cell by cell basis in the B0101 is tedious. Anything I might be missing? Keep in mind I literally have just started learning, so this is a step by step process for me.
    Thanks in advance!
    Post tune file and log files...
    what year/model/vehicle...?
    what mods (and cam specs)...?
    It might be easier to do Calc.VET.
    Nov 2013
    Just curious, did it happen at 25 kpa?
    Sent from my LG-LS980 using Tapatalk
    Feb 2016
    03 Honda S2000
    99-02 5.7 LS1
    TSP 228r Cam, 228/228 .600"/.600", 114 LSA
    Ported throttle body, LTs, ORX
    Don't have any logs right now. I generally would drive around some, stop, get the data, paste and multiply, then clear the data and drive around some more. Rinse, repeat. I'll save a few logs on the next run.
    Here is the current tune. I did the basic modifications from the idle thread to help get a steady idle, and I changed B0101 right around where the lean spike was happening to try and smooth that out since it was causing the car to stutter whenever it happened. Past that, it is all modifications from the Calc.MAFT.
    https://dl.dropboxusercontent.com/u/...5/Modified.ctz
    My biggest concern is that, for example this morning, driving around on the interstate, 70-80mph, partial throttle (5-10%), not accelerating, just cruising, and I'm sitting at 13.0.
    I could do the Calc.VET, though I would have to go about re-enabling/re-installing the MAF. Do you believe it would produce better results?
    Quote Originally Posted by Jetmech442 View Post
    Around the 25-35kpa range, yes.
    25 - 35 KPA would see you in Vacuem (over run) so a lean spike in that range would normally equal either a manifold leak or DFCO left active (assuming nothing odd in the tune if course).
    LS in an S2000 - Sweet! That must be a hoot :-)
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Feb 2016
    Quote Originally Posted by Happy Jim View Post
    Jim
    I haven't actually messed with anything regarding DFCO, so not sure. I could be mistaken on the kPA range, I was just going (off hand, right now) on where the odd spot in the B0101 map was (a large jump from the surrounding cells). I'm working on setting up CALC.VET to do some runs with it and see how it works out.
    And yeah, it is quite fun
    LS1 in an S2000 it now has all of its cylinders
    May 2011
    sounds familiar like the 2005 Tahoe doesn't it jetmech- same area where we see the extreme lean conditions
    99 ECSB 1500 6.0 lq9/243 2wd 3.42 in the works.
    Efans - CAI - Walbro 255lph - Eaton LSD
    BTR STAGE 3 truck cam - 60lb Inj - MP122HH
    FLT Level 5 - 3000 SC YANK
    Pacesetter LT's - ORY
    13.170 @ 103.33 Mph -
    Post pics of your engine bay, I want to see the MAF plumbing and air filter arrangement.
    Ok, MAF setup has MAF right after air filter, this will cause problems (air coming past the filter is not going straight).
    Ok, go with SD... in this case do Calc.MAFT and ignore the MAF calculation (unless you want to paste in the MAF calculation just for completeness sake).
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Calc.MAFT applying map to ve table
    By Mullnz86 in forum Gen III V8 Specific
    Last Post: July 12th, 2015, 04:53 PM
  3. SELBEN pid not available. Trying to setup calc.maft
    By SLP IROC-Z in forum Petrol / Gas
    Last Post: May 2nd, 2015, 09:57 AM
