Results 1 to 10 of 18
Thread: Another Bad ECM?
    Mar 2009
    Default Another Bad ECM?
    Did my repaired ECM go bad again?
    2002 Chevy Duramax with a few supporting mods.
    It looks that way.
    What happened?
    Mar 2009
    I was bench flashing it and this was what I got on every time trying to flash. Is there any chance of recovering it? It was rebuilt about a year and a half maybe two years ago.
    Was it recovered then flashed with TIS?
    Was it like this before attempting to flash it? In otherwords was this the first time you tried to program it on the bench?
    Mar 2009
    I've bench flashed this one a few times now over the year.
    I'm not sure how it was recovered I sent it into SoCal to be fixed and has been great until last night.
    Quote Originally Posted by WisconsinHick1 View Post
    Yeah, with TIS to get base files or with EFILive each time?
    Mar 2009
    EFILive was used each time.
    Jan 2006
    We are happy to take a look at it at no charge. Replacements are also available, factory programmed.
    Custom Tuning Services
    May 2016
    This is starting to bother me. I have used HP Tuners 50-60 times on my truck and many others with no issues or having to pull fuses. I upgraded my EFI Live cable so I could try the DSP5 on my truck but it looks like EFI Live is very unstable on this LB7 platform. I have been using HP Tuners for over ten years on my truck :(
    Mar 2009
    LB7's in general can be hit or miss, it's just how it is. I've flashed mine MANY times with NO issues over the last 7 years, as well as THOUSANDS of others, but LB7's can be a PITA if you hold your tongue wrong.
  1. HELP!! FLASH GONE BAD! Have i bricked my ECM?!
    By TravelinCummins in forum Cummins 5.9L
    Last Post: September 11th, 2013, 04:52 PM
  2. e38 possible bad ecm?
    By ls1mike in forum E37, E38 & E67 PFI ECM's
    Last Post: June 21st, 2013, 02:57 PM
  3. Bad ECM, license transfer?
    By vic in forum FlashScan V1
    Last Post: April 16th, 2013, 09:11 PM
  4. New ECM ? Have question bout vin license an efi live to new ECM
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:19 AM
  5. E38, L76 No spark, ECM or my bad??
    By Outwest34Au in forum E37, E38 & E67 PFI ECM's
    Last Post: August 9th, 2010, 12:40 AM
