Results 1 to 10 of 12
Thread: Is this real knock?
    May 2012
    Default Is this real knock?
    Hello.
    I have been testing and tuning for the past 6 months, car is an Australian HSV VZ Clubsport, engine is LS2 with E40 pcm.
    I have noticed some knock occurring in my log, it starts at frame 1974. knock peaks at 5.7 and then ramps down to 0. No audible knock was detected.
    So is this real knock?
    How can I better understand what is happening?
    Thanks.
    Manuel
    Does not look like it to me.
    ECM may be picking up some noise that sounds almost like knock...
    May 2012
    No worries.
    Thanks for that.
    Junior Member BHC5's Avatar
    Jun 2017
    Same question here. Just getting started tuning (novice) on new motor using LS1 type knock sensors on the side of an LS3 block. LS1 car pcm. I have tamed down the timing tables or so I think. 10.5:1 CR, running 91 octane pump gas (highest available here) The machine shop made the cylinder bores slightly looser than factory, and the rod and mains are on the + side too so I'm wondering if that is working against me. Log attached
    See your other thread.
    Jul 2003
    Quote Originally Posted by BHC5 View Post
    The problem with this is that the gate window is completely incorrect now and no tuning software has the tables to fix it. What os are you using?
    We don't have KS data for LS1/LS3 crossed sensors.
    Jun 2017
    I am using the original OS that came with the car from factory, 1998 LS1A. I wonder if a slipping clutch might be picked up and cause KR too?
    I had too thick of a shim behind slave cylinder, twin mcleod was slippping a little... ARGGG
    Jul 2003
    anyone interested in the KS data for bank to bank switchover?
    I believe they are very interested, I know of various people running crossed sensors.
    Thanks.
  1. e67 burst knock, cylinder knock pids
    By forcefedjunkie in forum Petrol / Gas
    Last Post: July 16th, 2014, 09:19 AM
  2. real time VE
    By myws6formula in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 14th, 2012, 01:48 PM
  3. Lots of Knock, is it real??
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 07:38 PM
  4. Real lean then real rich when zipping the throttle...
    By LS1_Dragster in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2011, 08:23 AM
  5. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 09:07 PM
