Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Is this real knock?
  1. #11
    Junior Member BHC5's Avatar
    Jul 2017
    Highlander, I have a pair of new LS2/3 side mount knock sensors and an adapter harness to connect to my LS1 car harness to the newer LS2/3 side-of-block knock sensors. Would this data you speak of allow one to use this setup with success???? Very Interested if so!!! https://forum.efilive.com/images/smilies/new/w00t.gif
  2. #12
    Jul 2003
    They work fine. Yes this calibration would be part of it. That being said, you need to wire them differently and you cannot use this sensors into the connector your stockers used to connect. EFILive has the PINout on its description when selecting the flat response sensors.
  1. e67 burst knock, cylinder knock pids
    By forcefedjunkie in forum Petrol / Gas
    Last Post: July 16th, 2014, 10:19 AM
  2. real time VE
    By myws6formula in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 14th, 2012, 02:48 PM
  3. Lots of Knock, is it real??
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 08:38 PM
  4. Real lean then real rich when zipping the throttle...
    By LS1_Dragster in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2011, 09:23 AM
  5. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 10:07 PM
