Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: turbo Silverado lean spikes/stumble
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Default turbo Silverado lean spikes/stumble
    Working on a friends turbo Silverado with an E38 PCM. I don't have a ton of experience with them, mostly LS1 PCMs... I am thinking that it has a mechanical issue causing the stumble/miss and unburnt fuel is showing up as spikes on the wideband. It is plenty rich right before it happens and the spikes are sporadic and very large - not typical lean tune characteristics. Any help ruling out a tune issue would be appreciated! Tune and log attached.
    Thanks!
    Bret
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Jun 2005
    Looks like the problem may have been the spark plugs - the guy he bought it from had the coldest LS race plugs you can buy in it... blowin the candles out! New plugs and we will give it another go.
    GM EFI Tuner
    May 2014
    Woo!
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Bret, good job on diagnosing the plugs
    Jun 2005
    Thanks Joe! Hope to get a chance to catch up with you soon! Been far too long my friend!
    GM EFI Tuner
    Quote Originally Posted by BLK02WS6 View Post
    Yeah, too long... it'll be nice to chat on the phone
    Jun 2005
    Unfortunately, it still has the issue... I'm going to try disabling the MAF and seeing if it does it. I saw a post on here where someone else had one that kept going lean with VE and MAF together, but wouldn't do it with each alone. His problem turned out to be some of VE calculation tables (forget which ones and I'm at work and can't look) and I tried those same changes, but it isn't helping this one...
    GM EFI Tuner
    Jun 2005
    I finally found a stock tune for this OS and started over - may have solved the issue. Still way too rich, but the lean spikes appear to be gone. Fingers crossed...
    GM EFI Tuner
    May 2014
    Git 'er done!
    Jun 2005
    Quote Originally Posted by Mean Green Z28 View Post
    Git 'er done!
    LOL- waiting on you!
    GM EFI Tuner
  1. Random lean spikes after letting off throttle
    By ferocity02 in forum Gen III V8 Specific
    Last Post: April 2nd, 2014, 05:22 AM
  2. Lean Cruise for a 09 Silverado
    By PACougar in forum Gen III V8 Specific
    Last Post: June 3rd, 2011, 08:19 AM
  3. 04 Silverado turbo 6.0 help.
    By Janke in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 1st, 2011, 10:56 AM
  4. Lean spikes commanded vs actual AFR
    By billyjo in forum Custom Operating Systems
    Last Post: January 24th, 2008, 05:58 PM
  5. Lean spikes
    Last Post: June 2nd, 2007, 04:20 PM
