This thing has me stumped. Still hitting the same wall at around 3k RPM. Running VE only right now and have it close enough that it shouldn't be doing this. Tune and log attached...
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
If you're correcting VE (VVE) did you first do this:
- disable MAF (make a MAF DTC trigger immediately)...?
- disable CL, LTFT, STFT...?
GM EFI Tuner
This thing is really frustrating me! During a pull, it bucks, and IBPW, airflow, and MAF frequency all get spikes. Also the wideband shows large spikes as well. This is in OL with the MAF online. I am going to unhook the signal wire and see what it does with the MAF offine.
I have found other posts with people having similar issues, and none of their remedies have helped this one. I will attach a log and the tune that it came from. Any ideas?
GM EFI Tuner
( BTW: 28 pid channels is making the sample rate slow down... try reducing to 24 pid channels, and in Edit->Properties->Logging select Stream Fast. )
( BTW: Log ETCTP instead of TP )
It looks like the ECM is closing the throttle due to exceeding one of the Electronic Throttle sanity tables (in Engine Diagnostics)... it's a matter of figuring out which one and increasing the upper threshold.... but, I see those are already maxed out... it seems the 512 g/s threshold (which is max) might be being exceeded.
Yes, try without MAF.
Thanks Joe! I thought I got all of the ETC tables, but I'll check again. So, if we are exceeding 512 g/s, that means we have to scale the tune, right?
Tuan - change the logs like he says above - I didn't notice you added some more. Always keep it to 24 channels. Change to ETCTP.
GM EFI Tuner
( look at bottom of PIDs tab and/or Data tab to see Pids Channel count... some pids take 2 or more channels )
Yes, you may have to scale VE/MAF/IFR (if you're using MAF).
