Thanks Joe - I was afraid of that... I don't know if he can pass emissions without the MAF.
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
Disregard the comment "(if you're using MAF)"...
the 512 g/s limit is in any g/s value inside the PCM, we can see it in GM.DYNCYLAIR and GM.DYNCYLAIR_DMA...
if you hit it (via MAF or DYNAIR) you have to scale.
E38 doesn't have those pids. Those are in g/cyl anyway - don't I need g/s?
GM EFI Tuner
We made a few hits with no MAF, and it definitely doesn't do the same thing... Scaled the same tune and we will hook the MAF back up.
GM EFI Tuner
I wish it was an LS1B... COS5 and good to go! I hate E38! It is definitely hitting something when on the MAF. I'm gonna keep on with this scaled tune and get the VVE worked in and then try the MAF again and see if it hits this wall. The small amount of driving he did last night on the VE with the scaled tune, it looks much better - rich, but much smoother... time will tell. If it would ever stop raining around here so he can drive it more!
GM EFI Tuner
When you scale, you also have to look at any table that references airmass (g) on its axis...
you now have to scale the axis, i.e. you have to shift the table contents down.
Yep, I think I got them all - went through it table by table. I didn't do any trans controller tables though... it seems to shift fine from what he tells me. I read that you may have to do any that reference torque, like the line pressure tables.
GM EFI Tuner
This is all so foreign to me ... and I'm a foreigner!
Sent from my SAMSUNG-SM-G900A using Tapatalk
LOL - your just a transplant, not a foreigner
GM EFI Tuner
