Results 11 to 20 of 21
Thread: 2009 Silvy with 4L80E swap ... can someone look over the TCM file?
  1. #11
    May 2014
    275/55-20 and GU6 3.42 ... I think I used 3.73 when I calculated oops
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  2. #12
    Aug 2006
    Here is a 2009 T42 4L80 calibration. It is stock other than the VIN being changed for a project. Maybe this might help.
    Jeff
  3. #13
    May 2014
    Thanks I'll check it out
  4. #14
    Jeff, thanks
  5. #15
    May 2014
    Hmm that's a lot of stuff that's different. Wonder if I should change vin and flash it after fixing gearing
  6. #16
    In that file the WOT MPH shift parameters are upside down (from the factory).
  7. #17
    May 2014
    Which table?
  8. #18
    The WOT shift MPH parameters:
    D1011 vs D1061 (and others)
    D2011 vs D2061 (and others)
    D3011 vs D3061 (and others)
    the downshift MPH has to be below the upshift MPH.
  9. #19
    May 2014
    Thanks will look at it
  10. #20
    Aug 2012
    Is there a 2012 vehicle 4l80e calibration I can use in my t42?
  1. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  2. 07.5-08 tcm in a 2009-10 LMM
    By IdahoRob in forum Allison 5 & 6 Speed
    Last Post: February 4th, 2011, 10:33 AM
  3. 2009 colorado 5.3 want to install a 4l80e
    By MECHAN12 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 21st, 2010, 11:52 AM
  4. anyone have a 2009+ A50 TCM file??
    By DURAtotheMAX in forum Allison 5 & 6 Speed
    Last Post: August 20th, 2010, 12:51 PM
  5. 2009 duramax tcm tuning
    By dgdyno in forum Allison 5 & 6 Speed
    Last Post: June 1st, 2010, 03:56 AM
