Results 1 to 10 of 14
Thread: cammed vz ss idle trouble
    Sep 2011
    Default cammed vz ss idle trouble
    hey guys i have a vz ss with an ls1 and comp cams 227/235 113lsa
    the tune was done by oztrack a few months ago but im not to happy wit the idle. sounds great as it warms up but at operating temp doesnt really sound like it has a cam in it. i have attached a copy of the tune file if anyone can have a look and tell me if they can fault it that would be great
    johncam8.ctz
    May 2012
    You're idling with 27 degrees of timing at idle. You're not using the base spark tables because of the thresholds set with B5916/B5917. If you want it to idle with a hint of cam lower your idle timing until you get the quality you want. My VZ with the 224/230 cam uses 21 degrees of timing which for me was a good compromise between quality and cam lope.
    B5916: 1.19 %TP
    B5917: 249 mph
    If operating point is below both of these then base spark tables are used, otherwise HO/LO tables are used, right...?
    So to me it looks like he is using base spark when TP drops below 1.19%, and HO/LO tables when TP goes above 1.19% (i.e. he's using TP only)... which in itself is odd when vehicle is moving, change of spark table as TP crosses 1.19%.
    or did I miss something obvious...?
    May 2012
    Ahh yeah of course. That'll learn me to quickly glance at something when tired LOL.
    113lsa will also tame down your idle some too.
    Sep 2011
    Quote Originally Posted by krisr View Post
    B5916: 1.19 %TP
    B5917: 249 mph
    i have looked at the above and have made changes but still no difference. i know the cam is 113lsa but it should still have some lope in it i have heard smaller cams sound bigger than this. it also doesnt feel right when sitting in the car it feels a bit rough and not the rough that that you get from a cam. as i said it sounds great when its cold and i do understand there will be more lope while cold but when its warm you wouldnt really think it has va cam at all. here is a log file that was used when the tune was done if it means anything.
    also if there is anyone local to brisbane southside that could go over the software with me that would be great as i do plan on a possible cam upgrade if i carnt get this right and i also have a nitrous kit ready for it to. i do have a pretty good understanding of the software just would be nice to have someone that could give me a few tips without having to spend a day digging through the forum to find what im looking for
    Senior Member auspeed's Avatar
    Jul 2010
    To toughen idle you normally, reduce spark timing, change target idle speed up or down depending on cam size & leanout the mixture a little in the VE table.
    Im sure Steve would do it for you if you asked.
    Sep 2011
    Quote Originally Posted by auspeed View Post
    I would have thought the same and I also expected better after sales support
    I had to fix a few things myself such as hanging idle on startup, stalling and had to take some timing out as it was showing 4deg of knock retard at 6000rpm not sure if it was false knock but not a risk in willing to take due to lack of support
    I will try what you have mentioned but staring to lean towards a bigger cam
    Aug 2013
    How much did you pay for that tune?
    Sep 2011
    Quote Originally Posted by statesman View Post
    I would rather not say I already made the mistake of mentioning the shop
    May 2012
    LOL, he's not got the best rap that bloke.
  1. Replies: 5
    Last Post: February 11th, 2014, 02:53 PM
  2. Cammed l31 Surging and in gear idle issues
    By HellKnightHicks in forum Vortec V6/V8 Specific
    Last Post: March 25th, 2013, 07:08 PM
  3. Replies: 1
    Last Post: March 15th, 2011, 08:17 PM
  4. Idle dip w/M6 cammed LS1 F-body
    By DrkPhx in forum Gen III V8 Specific
    Last Post: September 2nd, 2009, 05:49 AM
  5. Optimal Idle Timing for cammed LSx
    By Goldfinger911 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 06:56 PM
Tags for this Thread
