Results 1 to 9 of 9
Thread: map help
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Default map help
    Can't believe how much I've forgotten since I haven't been tuning much... I can't remember for the life of me how to change the number of digits that show up in a map cell. See the screenshot - I can't get the row labels to show the MAP values (3 digits) and the cells won't show lambda (digits). How do you change those? Thanks in advance!Click image for larger version.
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    In the map properties:
    - on the Row and Column tabs: do Paste Labels (first go to the tunetool table, and do Copy-with-Labels, then come back here and do Paste Labels on Row and Column tabs).
    - goto Data tab, set Precision to 3 or 4.
    Then in the map toolbar click x-bar to show each cell's average value.
    Also (in general), on each ot the Data, Row, Column tabs, checkmark Show Units.
    Jun 2005
    Still not working for a wideband lambda map. The MAP column labels are only showing 2 digits, the RPM only shows 3 digits, and the data values in the cells are only showing 2 digits. Changing the precision doesn't change it. Constrain cell size is unchecked. On my chart, lambda shows 4 digits. Also, if I copy the cell value and paste it in notepad, the value is 7 digits (i.e. 0.703667).
    GM EFI Tuner
    Jun 2005
    I don't get it - no matter what I do, I can't get the labels to show completely. In the user manual, under maps, data, it says: Minimum cell width: limits the minimum size (in pixels) to which the Scan Tool will shrink the cells in order to display the cell values. But this does not exist under map properties on the data tab.... seems to be my problem, but I don't see where to fix it!
    GM EFI Tuner
    Jun 2005
    So, it turns out constraining the cells and setting them bigger works...
    GM EFI Tuner
    Post a screenshot so I can check it.
    Jun 2005
    Here you go.
    GM EFI Tuner
    Ok, looks good. Remember to apply the low cell count filter and the transient filter before applying the correction.
  1. MAP offset and MAP scaler
    By RADustin in forum Gen III V8 Specific
    Last Post: March 17th, 2015, 01:59 AM
  2. preconfig map
    By ls1miata in forum Gen III V8 Specific
    Last Post: May 15th, 2009, 12:29 PM
  3. Map Question
    By DaddySS in forum General
    Last Post: April 15th, 2007, 04:43 PM
  4. Changing from a 2bar map to a 3bar map?
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 23rd, 2006, 04:31 PM
  5. KR Map
    By 98WhiteDevil in forum General
    Last Post: August 12th, 2006, 01:15 PM
