Try this:
Code:
# Units
*UNITS
#Code System Abbr Description
None None "" "No units"
# Add slot definitions here
*CLC-00-018
AFR 8.0 20.0 .3 "({EXT.AD1}*2.375)+7.3125)"
CALC.AFR_AEM F018 CLC-00-018 AFR 02-wide "AEM Wideband - Input 1"
# place at least 2 blank lines after this one (hit RETURN twice):
