Results 1 to 2 of 2
Thread: Rev limiter
    May 2008
    Default Rev limiter
    First where do we set the rev limiter up on a LML? Probly missed something simple but can't seem to get it to go over the stock 3400, also on this one I haven't had this issue before but even with traction control and stab trac disable it won't do a brake stall burnout. Hold the brakes and it won't allow it to fuel up but as soon as I let off the brake it breaks the tires loose and goes to the rev limiter and chops the throttle hard, shifts and then breaks the tires loose again. So where do we adjust the rev limiter?
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Mar 2013
    have you played with the torque control/ limiting? with the BTM Disabled it should smoke the tires. as for the rev limiter there are several tables that need to be adjusted to make sure fuel is not cut, I had to dig into the tcm to pull more rpm too. B0472, B2601, B0445, Petal Position tables & Torque to fuel tables.
  1. Rev limiter help
    By charcold-bowtie in forum Gen III V8 Specific
    Last Post: May 28th, 2009, 02:51 AM
  2. Rev limiter help
    By Badmire68 in forum Gen III V8 Specific
    Last Post: January 17th, 2008, 09:53 AM
  3. 97 C5 Rev Limiter ?
    By Kool C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2007, 11:28 AM
  4. rev limiter
    By CWR in forum Vortec V6/V8 Specific
    Last Post: July 4th, 2007, 04:40 PM
