Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 134
Thread: Volunteers needed for E38/E67 Calc.VET project.
    Aug 2013
    Thank you to all our volunteers... we have a nice variety of ECM's between all our volunteers, which should make this project more interesting.
    I'll send PM's to all of you.
    May 2014
    Umm I'm having issues tuning and if this will help me complete my vehicle while helping you'll I'm all in .. haha
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Aug 2013
    Quote Originally Posted by Mean Green Z28 View Post
    So to get you to volunteer, I have to tune your engine for you.
    I'll send you a PM.
    e83b is in the cruze/astra 1.6let.
    probably not much call for it as the stock vve/maf is pretty close in them even when you up the boost. the biggest thing that holds them back is the factory spark. but i have one as my daily so can get 40 minute logs each way to work if required.
    Aug 2013
    Having an engine with the vve/maf close might be really helpful for us... I'll send you a PM
    +1 that will give us a sanity check.
    E78... ok thanks, I'll add this to the descriptions.
    E39: I thought this was direct injected...?
    Where does E83 fit...?
    Yep, my bad you're correct Joe. E39/E39As are DI, I updated my previous post.
    No worries, I just wanted to make sure.
    Do you know what engine uses the E83 and is it DI...?
  9. #19
    I think it's the 1.6L I4 in the Opel Astra. I would be really interested if this is the case and want to see a calibration, if it's a DI engine then perhaps its an example of GM using 1 ECM for both Port Injection and Direct Injection...
  10. #20
    I'll put the wideband back in the car on the weekend then and start logging.
    fuel trims in it are usually around the -3% mark for ltft and stft's sit around +/- 4% depending on weather.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Volunteers needed for E38/E67 Calc.VET project.
    By statesman in forum Gen IV V8 Specific
    Last Post: May 30th, 2016, 09:19 AM
  3. E40-E38-E67 B5101 Calc Error?
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: October 24th, 2011, 04:34 PM
  4. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
  5. E67 & E38 pinouts needed.
    By nycblazer in forum E37, E38 & E67 PFI ECM's
    Last Post: March 6th, 2008, 04:36 AM
