Page 10 of 14 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 134
Thread: Volunteers needed for E38/E67 Calc.VET project.
  1. #91
    Oct 2010
    Now that I have the logging sorted out, what now? Get a 30+ min log and post it w/ my tune?
  2. #92
    Quote Originally Posted by statesman View Post
    The IFR table uses delta pressure... calculated from rail pressure and MAP.
    That's what I was hoping... his IFR being flat confirms this... but I want to know that his FPR is referenced.
    Mean Green Z28: is your FPR manifold referenced (is it close to the rails, and has a return tube going back)...?
    What is your measured rail pressure (measure with reference hose temporarily disconnected, i.e. FPR exposed to barometric pressure)...?
  3. #93
    What are some of those ^ parameters used for, if the fuel pump has variable speed, the FPR should smooth this out... right?
    ( I see that variable speed pump is set to No in this case... but what do you do when it is set to Yes...? )
  4. #94
    Quote Originally Posted by opcode View Post
    Drop the pid SAE.TP and replace it with GM.ETCTP, this brings the pid channel count up, to 31;
    Depending on whether SAE.LAMBDA works prooperly, we'll drop these pids:
    - E38.AFRATIO if SAE.LAMBDA works ok, or SAE.LAMBDA if it does not,
    - GM.ACCEP,
    - SAE.SHRTFT1,
    - SAE.SHRTFT2,
    - SAE.VSS,
    - SAE.ECT,
    this should bring the pid channel count down to 24.
    Did you do that ^
    Are we going to log MAF [g/s] or are we SD...?
    So are we going to use STFT's instead of LTFT's (STFT's are too dynamic, LTFT's are more filtered)...?
    Take a 20 minute log, see if you can get rpm into 4000-5000 range (just a few times), let's see what we get.
  5. #95
    From your log in post #84 above
    Bret scaled CL_STFT_MAF_VVE_REV_0038b.efi
    I see that the WB goes overly lean after each large throttle closure... I see DFCO is disabled.
    I see the STFT's trending up, pretty much pegging... we might want to see what the LTFT's are doing.
  6. #96
    May 2014
    the pressure you see is from the in tank controller, nothing at the rails .. it's a return-less system.
    Not quite sure of how it all works. We played with settings until we found that we can adjust the HI fueling pressure and it followed PE mode
    LTFT is turned off as we saw that going to 0 at WOT/PE mode so Bret played with the VVE more ... then we played with the Intake Temp vs. fueling table to account for temperature changes through winter/etc.. And Bret turned off DFCO.
    If there's other/better ways of doing it, I'm all ears! This was both our first time playing with a E38
  7. #97
    Quote Originally Posted by Mean Green Z28 View Post
    Then your IFR table is incorrect (it cannot be flat)... this will cause fueling to be wrong (ECM over-calculates the injector pulsewidth for non-WOT conditions).
    Which settings (table id #) did you play with...?
    LTFT's may go to zero at WOT, that's ok. I was mentioning DFCO to make sure that it wasn't DFCO that was causing the lean peaks after throttle closes.
    It's not a matter of other ways... we have to sanity check what is currently running, make sure we understand the model (for example, returnless fuel system uses an un-referenced FPR which requires the IFR table to be sloped.
    Yes, E38's seem very strange after working with LS1 and E40.
  8. #98
    Your B4001 IFR table:
    This ^ flat IFR table is for a MAP-referenced FPR (i.e. FPR has hose connecting to intake manifold) (this is a return fuel system).
    For a un-referenced FPR (returnless fuel system) the IFR has to be sloped (actually it goes as sqrt of pressure ratio).
    400 kPa (which the ECM has to interpolate) corresponds to WOT with no boost.
    < 400 kPa correspond to boost.
    > 400 kPa corresponds to part throttle conditions.
    468-488 kPa corresponds to closed throttle.
    Also: you have to measure rail pressure to correctly shift/scale the IFR table.
  9. #99
    May 2014
    Hmm wonder if we have to start all over. You think it's why we're having trouble fine tuning it? And also the wild crazy curves and slopes on VVE table?
    I'll be going back to a smaller 6766 Precision turbo and ditching the 7875 On3 turbo this year ... I'd like to enjoy it around town than be a highway warrior with high top end numbers. Maybe I'll change things around a bit to get things a bit better mechanically (like MAF locations etc.). I just don't feel like starting all over but if that's what it'll take, it'll have to be it.
    The truck barely gets off from a stop and can't ever do a burnout haha but I'm hoping it's the combo of the 78 and 4L80E and 3.42 gearing that's giving me the bad low end
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  10. #100
    May 2014
    I have sent InjectorConnection an email requesting the IFR table on these 80lb injectors. I know we were having issues with all this at the beginning when we decided to scale the tune. We were supposedly hitting the 512g/s limit I was told and what we ended up with was a bandaid I guess you could call.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Volunteers needed for E38/E67 Calc.VET project.
    By statesman in forum Gen IV V8 Specific
    Last Post: May 30th, 2016, 09:19 AM
  3. E40-E38-E67 B5101 Calc Error?
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: October 24th, 2011, 04:34 PM
  4. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
  5. E67 & E38 pinouts needed.
    By nycblazer in forum E37, E38 & E67 PFI ECM's
    Last Post: March 6th, 2008, 04:36 AM
