Bored, decked and honed L77 with JE FSR domed forged and steel top ring, forged rods. 370ci
821 control heads with hollow stainless, valvetrain tweaks / setup on Spintron. High squish smallest chamber 26.5 degrees advance using e90.
Tuned induction - air dam, OTR, 4" MAF with 1" straightener, ported TB and manifold with radius bars. Stock flex pump (ZL1) and injectors (LS7).
Exhaust tuned to ethanol - custom tri-y headers with megaphone expansion chambers, 2.5" straight through to x-pipe, per PipeMax.
Cam is 222/226 on 115 LSA, 109 ICL stock base circle to retain AFM so 0.550" lift via 1.85 rockers and beehives. Deac is 224/228, Phaser has 26 degrees authority with good PTV, though plug straps are indexed to avoid dome tops.
Phaser parked DCR using 0.006" is 10.2, fully retarded like a Prius I sometimes run pump gas.
222/226 115 +6
I don't remember, when phaser is off, where is the cam parked at...? and when phaser is at full, where is cam at...?
edit: I meant +6 for cam advance (when you graph ICL it moves to the left, putting ICL at 109 and ECL at -221).
I'm gonna take pir4te's lead and get mine up so I can help. I don't have much done to my car though.
I just sold a Boss302 with a 2.3L VMP on it. This is my first LS and I'm loving it. The ctsv couldn't have been a better choice.
I made the switch because my wife and I found out we have a little girl on the way.
I just recently got back to states after serving overseas I was stationed in Yokosuka Japan, car scene is quite different there. I'm not looking to make an all out monster just a head tuner. I have a goal of pulling a certain friend back in Florida. But I want to be responsible and behind my own tuning so I don't have to be at the mercy of a tuner. I like managing my own affairs. Just need guidance and tips and study time. And I'm always down to volunteer
Cam parked is 0 deg phaser retard, is 109 deg intake centre line, is cam fully advanced 6 deg.
2 deg commanded retard gets 111 ICL (4 deg advanced)
6 deg commanded retard gets 115 ICL (straight up)
13 deg commanded retard gets 122 ICL (7 deg retard), phaser fully retarded.
IVC @ 0.006" cam parked is 66 deg ABDC, 79 deg fully retarded.
Last edited by pir4te; October 15th, 2016 at 04:15 PM. Reason: Using deg symbol wipes out post?!
