Attempting to flash 2011 cummins mid flash it quit now i get a $0371 on the autocal and a U1601 in the truck attempted to use a recovery file and also updated the autocal to latest firmware no luck. any ideas what to do next?
Contact the tuner who sold you the package
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
it will check 100% then when it goes to flash it doesn't get past 0%
Ok, just trying to be REALLY clear here, when you start to program the ECM it instantly errors out with $0371 Transfer Suspended? Not half way, not at the end but right at the start with 0% shown?
correct it instantly goes to $0371 at 0%
Are you in a position to try pass-through flashing from a PC? I don't think it will make much difference but it might be worth a shot because unfortunately a replacement ECM is probably the only fix if it won't come good.
