Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 207
Thread: AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
  1. #101
    Jul 2016
    Not yet. testing is ongoing.
    You can send your 30-0333 unit in for re-flashing, if you want to try now.
  2. #102
    well i got my 3 here i need to send in somewhere but i want the serial protocol speed changed too. can you see if they will do that as standard in the new ones too?
  3. #103
    Jul 2016
    Go ahead and send those in to me. I can set the serial data-rate to 25Hz.
    I will see if I can get the AEM guys to adopt that rate for these new units as well. Shouldn't be too hard, as the serial data pins are not even populated on the OBDII units.
  4. #104
    Can you pm me your address. It'll be coming from AUS so it might take a week or 2 to get to you.
    Considering how utterly shit out postal service is.
  5. #105
    Jul 2016
    Sent.
  6. #106
    The serial pins aren't populated on the OBDII unit wiring harness, my current one doesnt have the pins. But, are they actually there on the gauge and can be used?
  7. #107
    So you need a different cable...?
  8. #108
    Jul 2016
    Yes. The 30-0333 gauges have the full serial and 0-5v functionality. Even though the cable/connector pins are not installed. You can order the pins from digikey.
    The pinouts are in the 30-0333 instructions.
  9. #109
    ok thanks
    ( I'm doing E38 and LS1B tuning, so I'm going to being using CAN bus and serial comms )
  10. #110
    Jul 2016
    The analog output on the new AEM gauges is, actually, very good. It has ground offset compensation and it updates 500 times per second; while having pretty low noise content.
    It is probably preferable to using the serial data, if you can.
  1. SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    By Black LS1 T/A in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2016, 04:11 PM
  2. V1, randomly cannot log AFR w/ AEM Uego
    By Tan327 in forum General
    Last Post: February 24th, 2012, 03:40 PM
  3. AEM UEGO wideband Pid?
    By derkscustomcars in forum External A/D inputs
    Last Post: August 8th, 2011, 02:42 AM
  4. An AFR Gauge is a pretty good E10+ fuel sensor
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2009, 07:16 PM
  5. AEM Gauge type 6 in 1 WB UEGO controller
    By JET LEE in forum Gen III V8 Specific
    Last Post: January 25th, 2007, 09:25 AM
