Page 21 of 21 FirstFirst ... 11192021
Results 201 to 207 of 207
Thread: AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
  1. #201
    Jul 2016
    so you can connect dual -334 wideband controllers to the CAN bus and be able to log both widebands from EFILive;
    Yes. That extra bit of functionality is responsible for the delay in getting EFILive support up and running. The dual-wideband code came right at the end of the qualification of the original 30-0334 package. It didn't make a lot of sense to release the single-only version, then, the dual-capable version.
    It's confusing enough, as-is
  2. #202
    Feb 2007
    Before I go out and purchase a couple of these 30-0334 units, AEM say for the 30-0333 units only compatible with post 2008 CAN, I have 2005 E40 CAN, will they still work?
  3. #203
    Jul 2016
    Pretty sure it will work. I think they only say 2008+ because it is guaranteed to be CAN.
  4. #204
    Jan 2013
    I have a 512k ls1b and the older uego 30-4110 logging via serial. is there any value in upgrading to the x-series?
    thanks
  5. #205
    Jul 2016
    Mostly the response speed. So that the WB data matches the RPM/MAP data. But, that only really applies if you use the analog or CAN data. The serial on the x-series defaults to 10Hz.
    The serial data can be sped up. But, that requires a re-flash. Actually, it doesn't. But AEM has not released the CAN API to change the settings.
  6. #206
    Jan 2013
    so the better response will be helpful, but since i have a ls1b that means there is nothing that i can do to go faster than 10hz with efilive, right?
  7. #207
    Quote Originally Posted by TrendSetter View Post
    The scan speeds for LS1B can be faster than 10Hz (if you sacrifice some PIDs). See page 186 of the V7 Scan Tool manual (Use the menu option from within the V7 Scan Tool: Help->Help Contents).
  1. SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    By Black LS1 T/A in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2016, 04:11 PM
  2. V1, randomly cannot log AFR w/ AEM Uego
    By Tan327 in forum General
    Last Post: February 24th, 2012, 03:40 PM
  3. AEM UEGO wideband Pid?
    By derkscustomcars in forum External A/D inputs
    Last Post: August 8th, 2011, 02:42 AM
  4. An AFR Gauge is a pretty good E10+ fuel sensor
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2009, 07:16 PM
  5. AEM Gauge type 6 in 1 WB UEGO controller
    By JET LEE in forum Gen III V8 Specific
    Last Post: January 25th, 2007, 09:25 AM
